[GRASS5] r.in.gdal
Tom Parker
tapadmin at swbell.net
Mon Jan 26 12:43:14 EST 2004
I did try installing various precompiled binaries as well as building from
source. If the update from 5.3 does not help I will follow up with the
debugging build.
Thanks,
Tom
-----Original Message-----
From: grass5-admin at grass.itc.it [mailto:grass5-admin at grass.itc.it]On
Behalf Of Markus Neteler
Sent: Monday, January 26, 2004 10:58 AM
To: grass-dev
Subject: Re: [GRASS5] r.in.gdal
On Mon, Jan 26, 2004 at 05:55:36PM +0100, Bernhard Reiter wrote:
> On Mon, Jan 26, 2004 at 10:10:41AM -0600, Tom Parker wrote:
> > I'm trying to resolve the r.in.gdal segmentation fault mentioned several
> > times on the mailing list over the past year. The problem shows itself
no
> > matter what type of raster file I try and import.
> > My sytem is redhat 9 with gdal/proj/grass all built from CVS.
> > After installing and/or building and installing several versions of both
> > grass and gdal as binaries or built from source the problem isn't fixed.
If
> > there is a simple fix I'd love to know it or I'd be happy to try and
help
> > fix the problem.
> Can you build with debugging support and try
> to see what the traceback says?
> Check: http://grass.itc.it/grassdevel.html
> for links to the "debugging" hints
> Are there any versions you didn't build yourself?
> Bernhard
An important bug was fixed Jan 23 (5.3-CVS), do you use that version?
Markus
grass5 mailing list
grass5 at grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
