[GRASS5] GRASS57: debian package build : dead symbolic links to 5.3 sources
Markus Neteler
neteler at itc.it
Tue Jan 27 10:32:52 EST 2004
On Tue, Jan 27, 2004 at 04:25:10PM +0100, Moritz Lennert wrote:
> Hello,
> I am trying to use dpkg-buildpackage on 5.7. However, I have the following
> problem:
> in debian/rules the following defines the location of the 5.3 sources:
> GRASS53SRC=../grass-5.3.0
> this is correct for me as I have:
> $ ls -l
> total 20
> drwxr-xr-x 23 mlennert mlennert 4096 2004-01-05 15:40 grass
> drwxr-xr-x 21 mlennert mlennert 4096 2004-01-27 16:10 grass51
> lrwxrwxrwx 1 mlennert mlennert 5 2004-01-27 15:24 grass-5.3.0 ->
> grass
> lrwxrwxrwx 1 mlennert mlennert 7 2004-01-27 15:24 grass-5.7.0 ->
> grass51
> However, in grass-5.7.0/include I have a series of dead links pointing to
> ../grass-5.3.0/src/include/*.h
> This should be ../../grass-5.3.0/src/include/*.h
> Where can I change the links that are created ?
In grass51/debian/rules you find the configuration. It seems,
that
- the link trick above doesn't work with 'make mix' done in
- something else not right.
Did you try to rename the dirs instead of linking?
Once we were able to make a debian package, if time, I'll
try again soon.
Markus
