[GRASS5] 5.7: v.in.ogr new feature
    Markus Neteler
    neteler at itc.it
    Wed Jan 28 11:09:48 EST 2004
now v.in.ogr is able to create locations from OGR sources
(implemented with much help from Paul Kelly).
Example:
GRASS 5.7.-cvs:~/test > ls roads.*
roads.dbf  roads.prj  roads.shp  roads.shx
GRASS 5.7.-cvs:~/test > v.in.ogr dsn=roads.shp out=roadstest location=ogrtest
The roads.shp will be imported into a new location 'ogrtest'.
Otherwise (without 'location=' parameter) it will be tested,
if the projection defined in 'roads.prj' matches the current
location definition.
Please try and complain,
 Markus
