[GRASS5] Testing Grass 5.3
Wed Jan 28 21:43:41 EST 2004
> > 2. A small annoying item with r.colors under tcltk. If you check the
> > 'rules' box, nothing happens. It **should** go to a terminal screen
> > and allow you to enter a set of color rules. This is what happens if
> > you use r.color via the terminal command line.
> Whether or not to use an xterm is set on a per-module basis; it isn't
> possible to only use one when certain options are used. So, we need to
> enable the use of an xterm always.
For now I just removed the "color=rules" option from the menu. There
should be a message displayed telling the user they can use the command
line if they want to do something more complicated, but I don't know how
to do that..
> Also, the tcltkgrass interface doesn't support the use of the rast=
> option.
Added. Also added some missing color= options.
Hamish
