[GRASS5] Testing Grass 5.3
    Michael Barton
    michael.barton at asu.edu
    Thu Jan 29 00:13:45 EST 2004
Hamish
Thanks. This will be an improvement to the menu. Thinking about it, is
it possible to do a r.colors ... colors=rules from the tcltk menu if it
is a separate menu selection (i.e., with its own dialog)?
Michael Barton
On Wednesday, January 28, 2004, at 07:43 PM, Hamish wrote:
>>> 2. A small annoying item with r.colors under tcltk. If you check the
>>> 'rules' box, nothing happens. It **should** go to a terminal screen
>>> and allow you to enter a set of color rules. This is what happens if
>>> you use r.color via the terminal command line.
>> Whether or not to use an xterm is set on a per-module basis; it isn't
>> possible to only use one when certain options are used. So, we need to
>> enable the use of an xterm always.
> For now I just removed the "color=rules" option from the menu. There
> should be a message displayed telling the user they can use the command
> line if they want to do something more complicated, but I don't know
> how
> to do that..
>> Also, the tcltkgrass interface doesn't support the use of the rast=
>> option.
> Added. Also added some missing color= options.
> Hamish
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
