[GRASS5] v.transform semi-error
Glynn Clements
glynn.clements at virgin.net
Thu Jan 29 16:30:20 EST 2004
Markus Neteler wrote:
> > Happy to try to clarify now I that I've figured out why I've been
> > confused. When you use v.transform from the tcltk menu system, it says
> > to input an ascii vector map. If you click the browse button (labeled
> > "vector_ascii", as is the output map name browse button), it goes to
> > the dig_ascii to search for a map. If you select a map from there it
> > appears in the dialog window. However, when you try to run v.transform
> > (clicking the "run" button) it says file not found.
> > The problem seems to be that the tcltk menu system has not been updated
> > to reflect changes in v.transform. In the manual, it says binary vector
> > file and v.transform from the command line works as specified there.
> OK, I have fixed that in tcltkgrassi (but didn't test).
> That's why 5.7 renders the menus automatically, no such update work :-)
How does it deal with the issues surrounding r.colors, as discussed in
the "Testing Grass 5.3" thread?
Glynn Clements <glynn.clements at virgin.net>
