[GRASS5] v.transform semi-error
Markus Neteler
neteler at itc.it
Fri Jan 30 03:26:51 EST 2004
On Thu, Jan 29, 2004 at 09:30:20PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > Happy to try to clarify now I that I've figured out why I've been
> > > confused. When you use v.transform from the tcltk menu system, it says
> > > to input an ascii vector map. If you click the browse button (labeled
> > > "vector_ascii", as is the output map name browse button), it goes to
> > > the dig_ascii to search for a map. If you select a map from there it
> > > appears in the dialog window. However, when you try to run v.transform
> > > (clicking the "run" button) it says file not found.
> > > The problem seems to be that the tcltk menu system has not been updated
> > > to reflect changes in v.transform. In the manual, it says binary vector
> > > file and v.transform from the command line works as specified there.
> > OK, I have fixed that in tcltkgrassi (but didn't test).
> > That's why 5.7 renders the menus automatically, no such update work :-)
> How does it deal with the issues surrounding r.colors, as discussed in
> the "Testing Grass 5.3" thread?
I think it doesn't.
So I change my statement to
"minimized update work with few outstanding issues".
You are welcome to suggest a solution.
Markus
