[GRASS5] What's holding 5.3.0 release?
Glynn Clements glynn.clements at virgin.net
Fri Jan 30 21:13:48 EST 2004
John Gillette wrote:
> For r.in.gdal, I made a small attempt to understand why some
> people were having seg-fault problems. I still don't understand
> this.
That's OK; nor does anyone else ;)
Seriously, there are a variety of reasons why r.in.gdal segfaults;
some of those reasons are better understood than others.
Some specifics which increase the likelyhood of r.in.gdal working are:
1. Using --with-gdal, so libgdal is linked directly rather than loaded
dynamically with dlopen().
2. Building GDAL with the --without-grass switch.
> Is there a difference in r.in.gdal in 5.3?
Only that --with-gdal is now the default.
Glynn Clements <glynn.clements at virgin.net>
