[GRASS5] Raster files suggestion: new directory layout
Paolo Cavallini cavallini at faunalia.it
Mon Jul 5 09:12:19 EDT 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I strongly support the idea. Perhaps this could give us a chance to improve
the data format as well? I think a limitation of rasters is that they are
always 8 bitpp, whereas in many cases (black&white maps) it would be more
appropriate to stick to 1bpp (far smaller files!).
But if this is complicated, of course it will be better to change the
directory layout ASAP.
All the best.
pc
At 14:43, lunedì 05 luglio 2004, Markus Neteler has probably written:
> Hi,
> another proposal: Let's simplify the raster file directory layout
> and have all files related to a raster map staying in a single
> directory (such as the 5.7 vector files). We already have discussed
> it some time ago.
> Advantages:
> - clean and understandable file structure
> - cleanup of raster API which is hard to understand at time
> - user can easily copy a map into another machine
>   (say, for backup reasons or whatever)
> - more?
> Disadvantages:
> - a script to migrate raster databases is needed
>   (as we once did for LZW elimination)
> When to implement it:
> - I suggest to do it asap in GRASS 5.7. While at migrating
>   their vector databases the users can also migrate the raster
>   databases (which is simply a 'mv' of the files).
> It could be implemented in two phases:
> - first read old raster file directory layout, but write new
>   layout
> - in a later version remove support for reading old layout
> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Paolo Cavallini
cavallini at faunalia.it            www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
GPG key @: www.faunalia.it/Public_key_Paolo.asc
Only free software: www.gnu.org / www.linux.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFA6VOz/NedwLUzIr4RAuwbAKC6w2YFRXV6m+dGIWEHmREniBwyVACdE0dZ
oNXo3U11DUQY4CLDd307LdU=
=6jwF
-----END PGP SIGNATURE-----
