[GRASS5] Raster files suggestion: new directory layout
Radim Blazek
blazek at itc.it
Mon Jul 5 10:25:13 EDT 2004
Any changes in raster directory structure should be done
only with other necessary changes in GRASS raster format,
which will break data compatibility, IMHO.
I think that to force users to convert (gigabytes) of data
for nothing is not the best idea.
On Monday 05 July 2004 15:12, Paolo Cavallini wrote:
> I strongly support the idea. Perhaps this could give us a chance to improve
> the data format as well?
Improvements in data format can give a chance to change also directory structure,
vice versa it does not make much sense I think.
> I think a limitation of rasters is that they are
> always 8 bitpp, whereas in many cases (black&white maps) it would be more
> appropriate to stick to 1bpp (far smaller files!).
> But if this is complicated, of course it will be better to change the
> directory layout ASAP.
> All the best.
> pc
> At 14:43, lunedì 05 luglio 2004, Markus Neteler has probably written:
> > Hi,
> > another proposal: Let's simplify the raster file directory layout
> > and have all files related to a raster map staying in a single
> > directory (such as the 5.7 vector files). We already have discussed
> > it some time ago.
> > Advantages:
> > - clean and understandable file structure
I think that the structure is understandable.
> > - cleanup of raster API which is hard to understand at time
Is it realy because of directory structure?
> > - user can easily copy a map into another machine
> > (say, for backup reasons or whatever)
Yes, that's true, but GRASS is designed so that users should not
access GISDBASE directly, only through GRASS modules.
For backup I would suggest r/v.pack/unpack
> > - more?
> > Disadvantages:
> > - a script to migrate raster databases is needed
> > (as we once did for LZW elimination)
The script is not the problem, the prolem is that the data
compatibility is broken.
> > When to implement it:
> > - I suggest to do it asap in GRASS 5.7. While at migrating
> > their vector databases the users can also migrate the raster
> > databases (which is simply a 'mv' of the files).
5.7.0 was already released, I was waiting with 5.7.0 until
format was stabilised.
> > It could be implemented in two phases:
> > - first read old raster file directory layout, but write new
> > layout
> > - in a later version remove support for reading old layout
Is anybody going to implement it in near future?
Radim
