[GRASS5] problems with GRASS 5.7 binaries for Windows
Glynn Clements glynn.clements at virgin.net
Mon Jul 12 03:18:18 EDT 2004
Hamish wrote:
> also, any ideas on starting GRASS from the Windows' desktop without
> having to type 'startx' and 'grass57'?
	startx /usr/X11R6/bin/xterm -e grass57
However, that will only run xterm, and you probably want to run a WM
as well, so create a script, e.g.:
	#!/bin/sh
	xterm -e grass57 &
	exec mwm
then run from another script, e.g.:
	#!/bin/sh
	/usr/X11R6/bin/startx /path/to/script
Note: the argument to startx has to begin with a slash, otherwise it
won't be interpreted correctly.
> There isn't enough memory to
> leave X running all the time, & the computer is needed for other things.
> Cygwin isn't needed for anything else (and if it is, I'm sure the person
> who knows UNIX can figure out another way in)
> ['startx' in .bash_profile and 'exec grass57' in .xsession ?]
If you always want to run GRASS when starting X, you can add:
	xterm -e grass57 &
to ~/.xsession. I suspect you probably don't want to run startx from
~/.bash_profile.
Glynn Clements <glynn.clements at virgin.net>
