[GRASS5] Re: problems with GRASS 5.7 binaries for Windows
Hamish
hamish_nospam at yahoo.com
Tue Jul 13 22:41:30 EDT 2004
> > GRASS 5.7 on Cygwin is very weak.
Just to document some other problems with the existing G5.7.0 binaries:
a) NVIZ segfaults in the usual way ('nviz -q' from the command line)
b) d.what.vect gives fails with 'Signal 11' when you click on the
monitor. 'd.what.vect -t' works ok (prints to the console).
And some solutions re. starting cygwin GRASS from an icon on the
windows desktop:
1) running startx automatically:
There is c:\cygwin\cygwin.bat.
I copied that to c:\cygwin\cygwin_goX.bat and edited the last line of
the file to be something like "bash -i --login -c startx". Then I made a
shortcut on the desktop to that batch file. Then right click on the
shortcut to cygwin_goX.bat, set to run minimized & change icon.
2) starting GRASS automatically:
Cygwin ignored .xsession, so I made a ~/.xinitrc file containing the
following: "exec xterm -e grass57".
I've attached to this email a better icon than the last one; a graphics
person might be able to clean it up a little more?
Hamish
Type: image/x-icon
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040714/1005d2c7/grass.bin
