[GRASS5] create rpm spec subdirectory for 5.7?
Bernhard Reiter
bernhard at intevation.de
Mon Jul 12 06:55:44 EDT 2004
If there are no further suggestions,
I would put in the work in the next days
to create the following structures in the grass51 CVS module:
rpm/
specs/
patches/
and move
grass.spec
to
rpm/specs/grass.mandrake.spec
Radim, Markus: Is that okay for you?
Best,
Bernhard
On Fri, Jul 09, 2004 at 05:19:39PM +0200, Silke Reimer wrote:
> On Thu, Jul 08, 2004 at 05:03:45PM +0200, Silke Reimer wrote:
> > I created a grass 5.7 package for fedora version 2 and a few library
> > packages
> > You can download the Spec-files with the patches as well as srpms
> > and rpms from
> > http://ftp.intevation.de/users/silke/packages/fedora/
> > They are located in SPECS, SOURCES, RPMS and SRPMS respectivly.
> I suggest to add a rpm directory in the GRASS CVS
> containing two directories: SPECS with different specfiles and
> SOURCES containing all distributions specific patches. Thus people
> who prepare packages for special distributions can easily maintain
> there package.
> Any comments?
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040712/498d1c77/attachment.bin
