[GRASS5] create rpm spec subdirectory for 5.7?
Radim Blazek
blazek at itc.it
Mon Jul 12 07:09:08 EDT 2004
On Monday 12 July 2004 12:55, Bernhard Reiter wrote:
> If there are no further suggestions,
> I would put in the work in the next days
> to create the following structures in the grass51 CVS module:
> rpm/
> specs/
> patches/
> and move
> grass.spec
> to
> rpm/specs/grass.mandrake.spec
> Radim, Markus: Is that okay for you?
> Best,
> Bernhard
Why patches? Why cannot it be fixed directly in original source files?
Radim
> On Fri, Jul 09, 2004 at 05:19:39PM +0200, Silke Reimer wrote:
> > On Thu, Jul 08, 2004 at 05:03:45PM +0200, Silke Reimer wrote:
> > > I created a grass 5.7 package for fedora version 2 and a few library
> > > packages
> > > You can download the Spec-files with the patches as well as srpms
> > > and rpms from
> > > http://ftp.intevation.de/users/silke/packages/fedora/
> > > They are located in SPECS, SOURCES, RPMS and SRPMS respectivly.
> > I suggest to add a rpm directory in the GRASS CVS
> > containing two directories: SPECS with different specfiles and
> > SOURCES containing all distributions specific patches. Thus people
> > who prepare packages for special distributions can easily maintain
> > there package.
> > Any comments?
