[GRASS5] GRASS 5.7: g.remove bug
Radim Blazek
blazek at itc.it
Mon Jul 12 12:57:57 EDT 2004
Fixed.
Radim
On Friday 02 July 2004 11:17, Hamish wrote:
> If you use v.external to connect to a shape file, then remove the shape
> file it no longer works. That's ok.
> When you try to remove the zombie vector file with 'g.remove vect=foo'
> it says:
> REMOVE [foo]
> ERROR: Cannot open layer 'foo_shp'
> and it doesn't remove anything....
> thanks,
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
