If you use v.external to connect to a shape file, then remove the shape file it no longer works. That's ok. When you try to remove the zombie vector file with 'g.remove vect=foo' it says: REMOVE [foo] ERROR: Cannot open layer 'foo_shp' and it doesn't remove anything.... thanks, Hamish
