[GRASS5] Re: GRASS 5.3 windows
Glynn Clements
glynn.clements at virgin.net
Thu Jul 1 18:25:09 EDT 2004
Richard Greenwood wrote:
> I think I see my mistake: 'make strip' strips from the files in the
> dist.i686-pc-cygwin directory. But 'make bindist' uses the files from
> the actual installation directory e.g. /usr/local/grass53
> Is this assumption correct?
Yes.
> And if so, why does bindist use the files
> from the installation directory rather than the dist.i686-pc-cygwin
> directory?
I don't know.
> And why does 5.3 seem to include debugging symbols when 5.0 and 5.7 do
> not? In all 3 cases I am configuring with:
> CFLAGS="-O2"
> LDFLAGS="-s -L/usr/local/lib -L/usr/X11R6/lib"
I have no idea. Any LDFLAGS settings should be honoured. Does the "-s"
actually show up in the link commands? Is it in the value of
LINK_FLAGS in src/CMD/head/head.<arch> (gmake build system) or
mk/vars.mk (alternate build system)?
Glynn Clements <glynn.clements at virgin.net>
