[GRASS5] Re: problems with GRASS 5.7 binaries for Windows
Hamish
hamish_nospam at yahoo.com
Tue Jul 13 00:08:16 EDT 2004
[Windows 2000]
> > I just did a new install of Cygwin + GRASS 5.7. Two problems:
> > [with spearfish5.7 + GRASS/gdal/xtcltk from
> > http://grass.ibiblio.org/grass57/binary/mswindows_cygwin/]
> > 1) v.info roads ERROR: pq.dll not found in PATH
> GRASS 5.7 on Cygwin is very weak. Regarding 1, do you have postgres
> installed?
Ok, missed that, now the vector modules work ok.
> > 2) xeyes, d.mon, d.rast all work ok.
> > Anything that uses tcltk doesn't, giving:
> > ERROR: libX11.dll not found in PATH
> Regarding 2, I don't know. Cygwin is *very* volitle.
I needed to install the XFree86-lib-compat package.
Now the GUIs work ..
I haven't tried NVIZ yes, bit everything else seems ok so far.
I guess we report bugs as we find them, then it gets stronger with time..
thanks,
Hamish
