[GRASS5] [bug #2522] (grass) Segfault in r.in.gdal on importing tiff
Paul Kelly via RT
grass-bugs at intevation.de
Wed Jul 14 06:08:27 EDT 2004
A bug was fixed on Monday that was causing segmentation faults when importing
non-georeferenced files using 5.7 r.in.gdal:
(It consists of two lines deleted from lib/proj/convert.c:
http://freegis.org/cgi-bin/viewcvs.cgi/grass51/lib/proj/convert.c.diff?
r1=1.9&r2=1.10 )
If you can, please try now (after re-compiling lib/proj) and see if it works.
-------------------------------------------- Managed by Request Tracker
