[GRASS5] [bug #2533] (grass) r.sunmask
Markus Neteler
neteler at itc.it
Wed Jul 14 06:12:52 EDT 2004
On Wed, Jul 14, 2004 at 10:46:42AM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2533
> Subject: r.sunmask
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: GRASS 5.7.0 (2004)
> for my DEM (2800 by 2800) it takes 40 hours to calculate the cast shadow
> with r.sunmask.
> for a hydrologic model i need the cast shadow for one year, time step one
> hour.
> is it possible to speed up the r.sunmask?
Maybe, this needs a voluteer.
> or is it even possible to
> calculate only for a mask which covers only one third of the DEM?
> thank you, sabine
You can simply use 'r.sun' instead of r.sunmask. It's much
faster.
Use the -s flag and see it's manual page:
"A map of shadows can be extracted from the solar incidence angle map (incidout).
Areas with zero values are shadowed."
Markus
