[GRASS5] Re: [GRASSLIST:3968] 5.7 v.in.ascii
Radim Blazek
blazek at itc.it
Tue Jul 20 04:33:12 EDT 2004
On Tuesday 20 July 2004 09:47, Hamish wrote:
> > > cat mpa.vector | v.in.ascii -t out=mpa
> anybody mind if I update 5.7's v.in.ascii to have a delim= option? Looks
> pretty straight forward; would allow input directly from .csv files from
> a spreadsheet which I think would help out the non-awk/cut/sed/regex
> folks quite a bit..
s.in.ascii,s.out.ascii,db.select,d.what.rast,r.cats,r.distance,r.stats,d.colorlist:
fs field separator
Radim
