[GRASS5] Re: [GRASSLIST:3968] 5.7 v.in.ascii
Wed Jul 21 05:39:27 EDT 2004
> > > > cat mpa.vector | v.in.ascii  -t out=mpa
> > anybody mind if I update 5.7's v.in.ascii to have a delim= option?
> > Looks pretty straight forward; would allow input directly from .csv
> > files from a spreadsheet which I think would help out the
> > non-awk/cut/sed/regex folks quite a bit..
> s.in.ascii,s.out.ascii,db.select,d.what.rast,r.cats,r.distance,r.stat
> s,d.colorlist:
> fs   field separator
ok, done.
Hamish
