[GRASS5] curses, foiled again!
Glynn Clements
glynn.clements at virgin.net
Thu Jul 29 04:15:39 EDT 2004
Roger Miller wrote:
> I've been trying to get Grass 5.3.0 to compile on a new SuSE 9.1 installation.
> Most things are working well, however...
> V_call.o in the vask library uses __waddbytes, which is defined in the curses
> library, but not in the ncurses library. The config routine specifies
> -lncurses for everything that uses libvask.a, but it doesn't specify
> -lcurses, which leaves __waddbytes undefined.
> I can go through the (long and tedious) labor of recompiling each of the
> failed modules manually, but I would rather find and fix the problem. Where
> and how would I look to fix this?
In all probability, the vask code is using the headers from one
version of curses but the programs which use it are being linked
against a library from a different version, and the two aren't
compatible.
Many of the curses "functions" which vask uses are actually actually
implemented as macros. FWIW, V_call.c uses the following curses
symbols:
curscr
stdscr
addch
addstr
getch
getyx
move
refresh
wrefresh
On my system, these result in the following curses dependencies in
V_call.o:
curscr
stdscr
waddch
waddnstr
wgetch
wmove
wrefresh
with the missing symbols corresponding to the following macros:
#define addch(ch) waddch(stdscr,ch)
#define addstr(str) waddnstr(stdscr,str,-1)
#define getch() wgetch(stdscr)
#define getyx(win,y,x) (y = (win)?(win)->_cury:ERR, x = (win)?(win)->_curx:ERR)
#define move(y,x) wmove(stdscr,y,x)
#define refresh() wrefresh(stdscr)
Presumably your curses.h defines one of these macros (probably addstr)
in terms of __waddbytes().
Essentially, you need to determine suitable settings for the
--with-includes= and/or --with-libs= configure switches such that the
compiler and linker will use a matching set of headers and library.
Note that the vask source code always refers to <curses.h>, but the
linker will use either -lncurses or -lcurses, depending upon which one
configure detects first (i.e. it will only use -lcurses if the check
fails for -lncurses).
One option is to create a temporary directory containing a symlink
named curses.h which refers to the ncurses version of the header, and
specify that via the --with-includes= switch.
Another option is to manually edit either src/CMD/head/head.<arch> or
mk/vars.mk (depending upon which build system is being used) and
change CURSES to use -lcurses instead of -lncurses.
Glynn Clements <glynn.clements at virgin.net>
