[GRASS5] GRASS 5.7.0 beta1
Martin Wegmann
mailinglist2_wegmann at web.de
Tue Jun 1 04:21:15 EDT 2004
Hello Radim,
two erros, probably not primarily due to the installation procedure but
nevertheless an error .. did it happen before?
1. v.digit: error while loading shared libraries: libtk.so.0: cannot open
shared object file: No such file or directory
ln -s to where?
2. the button options->toggle form mode keeps on top of every window until I
select it.
Martin
On Monday 31 May 2004 20:24, Martin Wegmann wrote:
> On Monday 31 May 2004 15:12, Radim Blazek wrote:
> > I have created beta1 source package for 5.7.0 :
> > http://mpa.itc.it/radim/grass-5.7.0beta1.tar.gz (6.5 MB)
> > It is full source code (make copymix; make srcdist)
> > with files copied from 5.3.0. This version is not tagged in CVS.
> > The purpose of this version is to check if configure, make,
> > make bindist and *-install.sh works on various platforms.
> > I would appreciate if volunteers could try to
> > ./configure (without --with-grass50 but with --with-postgres if possible)
> ./configure --without-postgres --with-tcltk-includes=/usr/include/tcl8.4
> --without-odbc --without-fftw
> > make
> > make bindist
> > install binary package
> > start grass57 installed from the binary package
> it built and installed fine on debian (unstable)
> regards, Martin
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
