[GRASS5] grass5.3.0 compilation problems
Fri Jun 4 03:09:53 EDT 2004
> > then I tried to compile and a lot of errors I obtained before were
> > removed, I only obtained:
> > Compilation error in module: src/raster/r.in.png (ignored)
> > Compilation error in module: src/raster/r.out.png (ignored)
> > Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
> > now: since I compiled without png support (with-png=no) the only problem
> > remains NVIZ...
> > during your last e-mail, you asked about the version of XFree I'm
> > using... it is the 4.3.0.dfsg.1-1
see here for needed Debian packages to compile GRASS:
http://article.gmane.org/gmane.comp.gis.grass.user/4788
> > gcc -I/home/ivan/Documents/GRASS/grass-5.3.0/src/include -g -O2
> > -I/usr/X11R6/include -I/usr/include/tcl8.3 -I/usr/include/tc$
> > <command line>:5:1: warning: "__STDC__" redefined
> > togl.c:38:66: X11/Xmu/StdCmap.h: No such file or directory
> Well, the standard XFree86 4.3.0 release includes X11/Xmu/StdCmap.h,
> so it appears that whoever built the package which you are using has
> removed it, or at least moved it to a separate package. You will have
> to ask the package maintainer about this issue.
This is provided by the "libxmu-dev" debian package.
('apt-file search X11/Xmu/StdCmap.h')
Hamish
