[GRASS5] grass5.3.0 compilation problems
ivan marchesini
marchesini at unipg.it
Fri Jun 4 04:52:18 EDT 2004
Thank you to all....
I will try to do all you said....
Ivan
Il ven, 2004-06-04 alle 09:09, Hamish ha scritto:
> > > then I tried to compile and a lot of errors I obtained before were
> > > removed, I only obtained:
> > > Compilation error in module: src/raster/r.in.png (ignored)
> > > Compilation error in module: src/raster/r.out.png (ignored)
> > > Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
> > > now: since I compiled without png support (with-png=no) the only problem
> > > remains NVIZ...
> > > during your last e-mail, you asked about the version of XFree I'm
> > > using... it is the 4.3.0.dfsg.1-1
> see here for needed Debian packages to compile GRASS:
> http://article.gmane.org/gmane.comp.gis.grass.user/4788
> > > gcc -I/home/ivan/Documents/GRASS/grass-5.3.0/src/include -g -O2
> > > -I/usr/X11R6/include -I/usr/include/tcl8.3 -I/usr/include/tc$
> > > <command line>:5:1: warning: "__STDC__" redefined
> > > togl.c:38:66: X11/Xmu/StdCmap.h: No such file or directory
> > Well, the standard XFree86 4.3.0 release includes X11/Xmu/StdCmap.h,
> > so it appears that whoever built the package which you are using has
> > removed it, or at least moved it to a separate package. You will have
> > to ask the package maintainer about this issue.
> This is provided by the "libxmu-dev" debian package.
> ('apt-file search X11/Xmu/StdCmap.h')
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
