[GRASS5] Re: mapset changing script
Radim Blazek
blazek at itc.it
Tue Jun 8 09:23:18 EDT 2004
On Sunday 06 June 2004 08:55, Hamish wrote:
> Is it ok to swap the order of the G_define_option()s in the code so it
> is ordered: g.mapset mapset=a location=b gisdbase=c ?
> That way you don't need to type mapset= every time, as it will be the
> most common change. Just 'g.mapset foo'.
You can make obvious things directly in CVS.
> Flag for not erasing displays? I'll often have 20 mapsets within a
> location specifying individual study sites, each with common map names.
> I then jump between them & d.redraw to quickly have a look at what is
> next door.
Special case, I think.
Radim
