[GRASS5] Re: [bug #2488] (grass) Transaction (glynn.clements@virgin.net)
Michael Barton
michael.barton at asu.edu
Wed Jun 16 19:55:27 EDT 2004
Glynn,
Thanks much for responding so quickly. Here is what happens. If you
just want to echo a string, it works OK. If you want to use the string
as an argument to an option, it won't work. For example, look at
d.vect. In the SQL box, you can put <field>=value and it works fine (no
spaces). But you cannot put <field>=value and <field2>=value2. This
generates an error that <field> value <field2> and value2 are illegal
values--i.e., it treats each part of the argument as a separate entry.
However you can do this on the command line with sql='<field>=value and
<field2>=value2'.
I ran into this trying to do a script for gdalwarp. I just hit it again
doing a script to make v.in.ascii read in a points file from a GUI
interface. To specify column definitions you need to do
v.in.ascii .... columns='xcoord double,ycoord double,name varchar(10)'
or something along that line.
This works from the command line. But in a g.parser GUI dialog,
anything you put into am entry box for this variable gets parsed as a
series of illegal entries rather than a single string argument. I've
tried to quote it in the script, manually when I enter it, and other
ways and have the same results.
Michael
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Jun 16, 2004, at 4:32 PM, Glynn Clements via RT wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2488
> Thu, Jun 17 2004 01:32:48: Request 2488 was acted upon.
> Transaction: Mail sent by glynn.clements at virgin.net
> Queue: grass
> Area: grass5.7
> Subject: GRASS 5.7 WISH - improve string reading ability in
> g.parser
> Owner:
> Requestors: michael.barton at asu.edu
> Status: open
>> Subject: GRASS 5.7 WISH - improve string reading ability in g.parser
>> grass binary for platform: MacOSX
>> GRASS Version: 5.7 26-03-2004
>> g.parser has difficulties parsing strings with spaces in them. If you
>> enter a string with spaces, it treats each word as a separate, illegal
>> entry for that variable.
> I can't reproduce this behaviour with 5.3, and g.parser itself is
> unchanged in 5.7 (although G_parser() has some changes).
> Are you sure that the problem isn't in the way that the GIS_OPT_*
> variables are used in the script? Have you tried it with the test.sh
> script from the g.parser directory? E.g.
> $ test.sh rast=fields vect=fields option1='hello world'
> Flag -f not set
> Value of GIS_OPT_option1: 'hello world'
> Value of GIS_OPT_raster: 'fields'
> Value of GIS_OPT_vect: 'fields'
> Glynn Clements <glynn.clements at virgin.net>
> --- Headers Follow ---
>> From glynn.clements at virgin.net Thu Jun 17 01:32:48 2004
> Return-Path: <glynn.clements at virgin.net>
> Delivered-To: grass-bugs at lists.intevation.de
> Received: from mail.intevation.de (aktaia [212.95.126.10])
> by lists.intevation.de (Postfix) with ESMTP id 045B5139C9
> for <grass-bugs at lists.intevation.de>; Thu, 17 Jun 2004 01:32:48 +0200
> (CEST)
> Received: from localhost (localhost [127.0.0.1])
> by mail.intevation.de (Postfix) with ESMTP id 1273A36F10
> for <grass-bugs at lists.intevation.de>; Thu, 17 Jun 2004 01:32:49 +0200
> (CEST)
> Received: from n066.sc1.cp.net (h13.rdg.cp.net [209.228.29.63])
> by mail.intevation.de (Postfix) with ESMTP id 145A936E19
> for <grass-bugs at intevation.de>; Thu, 17 Jun 2004 01:32:47 +0200 (CEST)
> Received: from cerise.nosuchdomain.co.uk (62.252.68.153) by
> n066.sc1.cp.net (7.0.027.3-1)
> id 40C8ED090009B97D; Wed, 16 Jun 2004 23:32:36 +0000
> Received: (from glynn at localhost)
> by cerise.nosuchdomain.co.uk (8.11.6/8.11.6) id i5GNVED01602;
> Thu, 17 Jun 2004 00:31:14 +0100
> From: Glynn Clements <glynn.clements at virgin.net>
> MIME-Version: 1.0
> Content-Type: text/plain; charset=us-ascii
> Content-Transfer-Encoding: 7bit
> Message-ID: <16592.55362.168057.819805 at cerise.nosuchdomain.co.uk>
> Date: Thu, 17 Jun 2004 00:31:14 +0100
> To: Request Tracker <grass-bugs at intevation.de>
> Cc: grass5 at grass.itc.it
> Subject: Re: [GRASS5] [bug #2488] (grass) GRASS 5.7 WISH - improve
> In-Reply-To: <20040616222010.E1D3B13B4B at lists.intevation.de>
> References: <20040616222010.E1D3B13B4B at lists.intevation.de>
> X-Mailer: VM 7.07 under 21.4 (patch 15) "Security Through Obscurity"
> XEmacs Lucid
> X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0
> tests=BAYES_00
> X-Spam-Level:
> -------------------------------------------- Managed by Request Tracker
