[GRASS5] GRASS 5.7.0 beta1
Mon Jun 28 04:58:24 EDT 2004
> > I have also fixed the 'magic' bug in attributes form (update mode did
> > non work). It was most probably caused by GRASS_FORM_MODE variable
> > which I replaced by'-e' flag in d.what.vect. d.m global option moved
> > to vector's options. d.what.vect will from now by default use VIEW
> > mode.
> Is there an option to set the default mode to EDIT, e.g. with a alias?
> If so, where is the appropriated place to put this alias or is there
> probably another option to set EDIT to the default vector option?
quick and dirty, sorry if it is obvious:
add this to "~/.grass.bashrc":
alias d.what.vect='d.what.vect -e'
Hamish
