[GRASS5] GRASS 5.7.0 beta1
Stephan Holl
sholl at gmx.net
Sun Jun 27 06:38:22 EDT 2004
Hello Radim,
On Tue, 1 Jun 2004 15:14:35 +0200 Radim Blazek <blazek at itc.it> wrote:
> I have also fixed the 'magic' bug in attributes form (update mode did
> non work). It was most probably caused by GRASS_FORM_MODE variable
> which I replaced by'-e' flag in d.what.vect. d.m global option moved
> to vector's options. d.what.vect will from now by default use VIEW
> mode.
Is there an option to set the default mode to EDIT, e.g. with a alias?
If so, where is the appropriated place to put this alias or is there
probably another option to set EDIT to the default vector option?
Thanks for your help
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040627/dbfd6f7e/attachment.bin
