[GRASS5] grass++
Sabine Grabner
csab7771 at uibk.ac.at
Wed Jun 30 05:12:22 EDT 2004
i compiled grass++. here are a few suggestions/questions:
1. it was not clear from first view that one need to compile grass from source
first (i used precompiled binaries before and was wondering about /dist.
$ARCH). maybe it should be mentioned in the manual for those who are not so
familiar with installing.
2. i compiled the library in /home/sabine/diss/grass++0.2 and moved libgrass+
+.so to /usr/local/lib. is this working as the header files remain in /home/
sabine... ?
3. the GISBASE environment variable need to be set. how can i do that?
thanx, sabine
