[GRASS5] grass++
Radim Blazek
blazek at itc.it
Wed Jun 30 06:38:29 EDT 2004
On Wednesday 30 June 2004 11:12, Sabine Grabner wrote:
> i compiled grass++. here are a few suggestions/questions:
> 1. it was not clear from first view that one need to compile grass from
> source first (i used precompiled binaries before and was wondering about
> /dist. $ARCH). maybe it should be mentioned in the manual for those who are
> not so familiar with installing.
> 2. i compiled the library in /home/sabine/diss/grass++0.2 and moved
> libgrass+ +.so to /usr/local/lib. is this working as the header files
> remain in /home/ sabine... ?
> 3. the GISBASE environment variable need to be set. how can i do that?
GISBASE is path to the directory where grass is installed.
Radim
