[GRASS5] grass 5.3 CVS - r.in.gdal compilation error
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Mar 4 07:37:03 EST 2004
On Thu, 4 Mar 2004, Otto Dassau wrote:
> Dear list,
> I installed gdal from CVS today, it compiled without problems, but in
> GRASS 5.3 CVS from today, r.in.gdal compiles this error message:
> gcc -L/daten/software/grass53/src/libes/LIB.i686-pc-linux-gnu
> -Wl,--export-dynamic -o
> /daten/software/grass53/dist.i686-pc-linux-gnu/etc/bin/cmd/r.in.gdal
> OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/gbgetsymbol.o
> OBJ.i686-pc-linux-gnu/gdalbridge.o \
> /daten/software/gdal/libgdal.la -lgproj -lproj -lgis -lI
> -lgmath -lm -lz
> /daten/software/gdal/libgdal.la: file not recognized: File format not
> recognized
> collect2: ld returned 1 exit status
> make: ***
> [/daten/software/grass53/dist.i686-pc-linux-gnu/etc/bin/cmd/r.in.gdal]
> Fehler 1
> what can I do to make r.in.gdal compile?
Maybe install it rather than linking to it from the compile directory (if
that's what you're doing). Or compile it without using libtool
(--without-libtool).
This isn't really a GRASS question.
