[GRASS5] can't get 5.7 to get past ./configure
Markus Neteler
neteler at itc.it
Mon Mar 8 06:13:42 EST 2004
On Mon, Mar 08, 2004 at 11:02:55AM +0000, Paul Kelly wrote:
> "Jeff D. Hamann" wrote:
> > >> when I attempt to run make, I get,
> > >> $ make
> > >> "./include/Make/Grass.make", line 235: Missing dependency operator
> > >> "./include/Make/Grass.make", line 308: Need an operator
> > >> "Makefile", line 51: Missing dependency operator
> > >> "Makefile", line 53: Need an operator
> > >> make: fatal errors encountered -- cannot continue
> But as you almost certainly will run into problems with your make later
> in the compilation, I would suggest using GNU make. This is really
> required for GRASS 5.7 (and parts of 5.3 as well) but I'm not sure if it
> is listed as something you must install.
Yes, the REQUIREMENTS.html of 5.7 lists it as second entry.
Markus
