[GRASS5] raster commands in 5.7
Michael Barton
michael.barton at asu.edu
Fri Mar 12 10:52:14 EST 2004
On Friday, March 12, 2004, at 04:01 AM, grass5-request at grass.itc.it
wrote:
>> On the subject of GRASS 5.7, I noticed previously that a lot of raster
>> commands seem missing (especially I/O, r.support, and modeling). Is
>> this simply because they have not yet been updated? Will most raster
>> commands work in 5.7 or do they all need tweaking?
> Please list what you need. We have 92 raster commands present,
> I don't see how "a lot of raster commands" are missing. GRASS 5.3
> comes with 129 raster commands, but contains several commands which
> are not needed (so I excluded them for now).
> Just tell me which command(s) you need and I'll add them.
> Markus
You are right. I am guilty of a bit of hyperbole and it is not 'a lot'.
However, I did notice more than a few and some of that seemed
important. I started making a list a couple months back when I went
through all the commands to do the first run on a 5.7 menu. However,
I've let that sit while I've been engulfed by the normal semester
insanity and working on the GUI for 5.3.
I will try to get you that interim list soon. When I start in on the
5.7 GUI in earnest, I will note all 'missing' raster commands (and any
others--e.g. none of the scripts are there) in a systematic way. I'm
sure you are right in that some of these may no longer be needed.
Michael
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
