[GRASS5] raster commands in 5.7
Markus Neteler
neteler at itc.it
Fri Mar 12 11:24:18 EST 2004
On Fri, Mar 12, 2004 at 08:52:14AM -0700, Michael Barton wrote:
> On Friday, March 12, 2004, at 04:01 AM, grass5-request at grass.itc.it
> wrote:
> >>On the subject of GRASS 5.7, I noticed previously that a lot of raster
> >>commands seem missing (especially I/O, r.support, and modeling). Is
> >>this simply because they have not yet been updated? Will most raster
> >>commands work in 5.7 or do they all need tweaking?
> >Please list what you need. We have 92 raster commands present,
> >I don't see how "a lot of raster commands" are missing. GRASS 5.3
> >comes with 129 raster commands, but contains several commands which
> >are not needed (so I excluded them for now).
> >Just tell me which command(s) you need and I'll add them.
> >Markus
> You are right. I am guilty of a bit of hyperbole and it is not 'a lot'.
> However, I did notice more than a few and some of that seemed
> important. I started making a list a couple months back when I went
> through all the commands to do the first run on a 5.7 menu. However,
> I've let that sit while I've been engulfed by the normal semester
> insanity and working on the GUI for 5.3.
Michael,
for me (anyone else) it is in the range of minutes to add missing
commands:
- create a Makefile (recycle another one)
- create a directory
- add to tools/link.conf the crosslinking to 5.3
- make mix
- compile
Whatever you remember to be missing, just post it.
Sorry to insist, but we should make the move to 5.7 and not
stick with older versions for years.
> I will try to get you that interim list soon. When I start in on the
> 5.7 GUI in earnest, I will note all 'missing' raster commands (and any
> others--e.g. none of the scripts are there) in a systematic way. I'm
> sure you are right in that some of these may no longer be needed.
ok, I'll stay tuned.
Markus
