[GRASS5] help with recalcitrant vector area
Michael Barton michael.barton at asu.edu
Fri Mar 19 19:07:50 EST 2004
I am completely at a loss.
I am simply trying to use countries of Europe that I imported from an
ESRI shapefile. They imported more or less OK overall and seemingly
fine for the countries of the Iberian peninsula that I want to see as
areas. BUT only one of these shows up as an area--Portugal.
When I go into v.digit I am unable to turn Spain into an area. I place
the centroid  point, but when I try to set a boundary line (area edge),
it says 'no line can be found'. I've tried labeling and unlabeling
lines. When they are labeled, I can indeed select a line that forms
part of the boundary of Spain, but it still won't make an area.
("failed to create area") All the nodes are snapped. I can't find a
single break in the lines--even at high zoom levels.
I've run v.support, v.spaghetti, v.build.polylines endlessly with no
luck. I've snapped nodes at various tolerances, auto-labeled all lines
and removed all labels. I imported the file into GRASS 5.7. Behold
Spain is a vector area. But when I export it back to GRASS 5.3, it
turns back into a line.  Argh!!!
What am I missing (besides my sanity).
Michael Barton
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040319/8b56938d/attachment.bin
