[GRASS5] 5.7 v.digit Cygwin fails
Markus Neteler neteler at itc.it
Mon Mar 22 04:38:54 EST 2004
Rich,
looking at that message again: did you launch it from the
display manager? I think yes:
 GRASS 5.7.-cvs:~/grass57/display/d.m > grep v.digit *
 vector.tcl:    set cmd "v.digit -n map=$opt($id,map)"
Can you please try to launch it from cmd line:
 d.mon x0
 v.digit -n map=fart
Does this work at least?
 Markus
On Thu, Mar 18, 2004 at 05:25:37PM -0700, Richard Greenwood wrote:
> 5.7 v.digit fails under Cygwin, error pasted log below. I built 5.3 and
> 5.7 from March 13, 2004 snapshot. Any suggestions?
> Regards,
> Rich
> === error log ================
> child killed: segmentation violation
>     while executing
> "exec v.digit -n map=fart >@stdout 2>@stdout"
>     ("eval" body line 1)
>     invoked from within
> "eval "exec $cmd >@stdout 2>@stdout""
>     (procedure "Dm::execute" line 12)
>     invoked from within
> "Dm::execute $cmd"
>     (procedure "DmVector::WorkOnVector" line 21)
>     invoked from within
> "DmVector::WorkOnVector $sel"
>     ("vector" arm line 2)
>     invoked from within
> "switch $type {
>         raster {
>             return
>         labels {
>             return
>         vector {
> 	    DmVector::WorkOnVecto..."
>     (procedure "Dm::edit" line 10)
>     invoked from within
> "Dm::edit"
>     ("uplevel" body line 1)
>     invoked from within
> "uplevel \#0 $cmd"
>     (procedure "Button::_release" line 18)
>     invoked from within
> "Button::_release .mainframe.topf.tb0.bbox2.b5"
>     (command bound to event)
> Richard Greenwood
> www.greenwoodmap.com
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
