[GRASS5] [bug #2387] (grass) Makefiles assume that
Markus Neteler
neteler at itc.it
Mon May 3 06:10:48 EDT 2004
On Sat, Apr 17, 2004 at 09:13:53PM +0100, Glynn Clements wrote:
> Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=2387
> > Subject: Makefiles assume that
> > Platform: other
> > grass obtained from: CVS
> > grass binary for platform: Compiled from Sources
> > GRASS Version: grass 5.7 from CVS checked out 20040417
> > In a number of places the Makefiles in grass 5.7 assume that "make" is
> > GNU make. This makes users of systems where "make" is something else
> > and GNU make is called "gmake" have to take extra steps (like making
> > symlinks to GNU make and rearranging their paths) to build grass.
> > If the makefiles used the MAKE variable (e.g. always use $(MAKE)
> > instead of make in rules that invoke make) then this would't be a
> > problem, as the user could than specify which version of make to use.
> FWIW, here's a list:
> lib/db/Makefile: test ! -d latex || (cd ./latex && make clean)
> lib/db/Makefile: (cd ./latex && make)
> lib/db/Makefile: (cd ./latex && make pdf && mv refman.pdf grass57dbmi_`date '+%Y_%m_%d'`_refman.pdf)
> lib/vector/Makefile: test ! -d latex || (cd ./latex && make clean)
> lib/vector/Makefile: (cd ./latex && make)
> lib/vector/Makefile: (cd ./latex && make pdf && mv refman.pdf grass57vlib_`date '+%Y_%m_%d'`_refman.pdf)
> tools/Makefile: (cd timer ; make)
> vector/v.clean/Makefile: cd test; make
> Makefile: (cd $$subdir && make) || exit 1; \
> Makefile: (cd $$subdir && make clean) || exit 1; \
> Makefile: (cd lib/db/ ; make htmldocs)
> Makefile: (cd lib/vector/ ; make htmldocs)
> Makefile: (cd lib/db/ ; make pdfdocs)
> Makefile: (cd lib/vector/ ; make pdfdocs)
> visualization/nviz/Makefile: cd src ; make
> visualization/nviz/Makefile: (cd src && make clean) || exit 1;
> raster/r.le/r.le.setup/Makefile: (cd polytocell/ ; make )
> raster/r.terraflow/IOStream/lib/Makefile: (cd src ; make)
> raster/r.terraflow/Makefile: (cd IOStream/lib ; make)
> raster/r.terraflow/Makefile: (cd IOStream/lib ; make clean )
> Also, both Makefile and include/Make/Platform.make.in set the MAKE
> variable; this gets set by MAKE itself, and shouldn't be overriden.
Fixed in CVS.
Markus
