[GRASS5] [bug #2397] (grass) v.clean dissolve problem for areas
Request Tracker
grass-bugs at intevation.de
Tue May 4 06:06:49 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2397
Subject: v.clean dissolve problem for areas
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: GRAS 5.7 CVS from april 2004
This problem occured a couple ot weeks ago using v.extract, but according
to Radim is a v.extract 'pseudo bug' and would have to be solved by v.clean.
| 1 | 2 |
| c | |
| +--+ c |
| |c | |
| |3 | |
v.extract 1,2: result:
| 1 | 2 |
| c | |
| +--+ c |
areas without centroid occur, because
former area 3 still is surrounded by boundaries and
2 areas but without centroid. To solve this, it would be necessary
to add a dissolve functionality into v.clean to add former area 3 to
one of the other areas (1 or 2).
hope the problem becomes clear
thanks
Otto
-------------------------------------------- Managed by Request Tracker
