[GRASS5] [bug #2397] (grass) v.clean dissolve problem for areas
Otto Dassau
otto.dassau at gmx.de
Tue May 4 14:42:40 EDT 2004
Radim Blazek schrieb:
> On Tuesday 04 May 2004 12:06, Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=2397
> > Subject: v.clean dissolve problem for areas
> > Platform: GNU/Linux/i386
> > grass obtained from: Trento Italy site
> > grass binary for platform: Compiled from Sources
> > GRASS Version: GRAS 5.7 CVS from april 2004
> > This problem occured a couple ot weeks ago using v.extract, but according
> > to Radim is a v.extract 'pseudo bug' and would have to be solved by
> > v.clean.
> > | 1 | 2 |
> > | c | |
> > | +--+ c |
> > | |c | |
> > | |3 | |
> > v.extract 1,2: result:
> > | 1 | 2 |
> > | c | |
> > | +--+ c |
> This is obviously bug, correct is:
> | 1 | 2 |
> | c | |
> | +--+ c |
> Are you sure that you get the wrong result above?
> For me v.extract gives correct result.
> > areas without centroid occur, because
> > former area 3 still is surrounded by boundaries and
> > 2 areas but without centroid. To solve this, it would be necessary
> > to add a dissolve functionality into v.clean to add former area 3 to
> > one of the other areas (1 or 2).
> > hope the problem becomes clear
> No, not for me. What did I say about 'pseudo bug', dissolve functionality and v.clean?
Hi Radim,
ok, sorry. I will try to show with the new spearfish57 data.
this is the original soils map from spearfish57
Number of nodes : 2181
Number of primitives: 2883
Number of points : 0
Number of lines : 0
Number of boundaries: 2146
Number of centroids : 737
Number of areas : 737
Number of isles : 42
Number of incorrect boundaries : 7
Then I extracted all areas with cat>20:
v.extract in=soils out=soils2 type=area,centroid where='cat>20'
Number of nodes : 1960
Number of primitives: 2484
Number of lines : 0
Number of boundaries: 1908
Number of centroids : 576
Number of areas : 595
Number of isles : 71
Number of areas without centroid : 19
in the resulting map centroids are missing, because some areas seem to
be
not correctly extracted. And you said 'some time ago' that this is not a
v.extract
problem and would have to be solved by adding a dissolve function to
v.clean, as
described with the upper figures.
I hope it is clearer now?
Otto
