[GRASS5] GRASS 5.3 release
Glynn Clements
glynn.clements at virgin.net
Thu May 6 20:35:16 EDT 2004
Paul Kelly wrote:
> > shared libs working on all but Cygwin ?
> Not a big job to get them working on Cygwin:
No? Is it no longer necessary to create a .def file for DLLs?
> 1) make driverlib static on all platforms (I remember Glynn saying this
> was generally a good idea as the way it is written it will always
> reference functions in other libraries that might not have been compiled
> yet)
Actually, the issues are:
a) that driverlib references functions which are defined in the
executable, and
b) main() is defined in the library.
> Getting it working on OSX is a bigger problem and requires lots of
> tedious work removing multiply defined symbols, but will be done for 5.4
Can you provide more details? Maybe I'm missing something, but I can
only find around 20 symbols which appear to be problematic.
Glynn Clements <glynn.clements at virgin.net>
