[GRASS5] 5.7: man pages extended
Markus Neteler neteler at itc.it
Mon May 10 06:07:07 EDT 2004
On Thu, May 06, 2004 at 06:16:05PM +1200, Hamish wrote:
> > I have modified the build script which generates
> > the HTML manual pages in 5.7 to add a one-line
> > description of each module. Like that you can
> > quickly search for a certain functionality.
Now online at:
 http://grass.itc.it/grass51/manuals/html57_user/index.html
(auto-generated from CVS)
> > So please keep on writing reasonable stuff into
> >  module->description =
> > Another useful extension in the C code might be
> > the introduction of keywords. Per module maybe
> > 2-5 keywords. But yes, a lot of work.
> Could it just search through the module->description strings? most of
> the keywords will already be in there, & if not probably should be.
> Adding keywords to every single module is a lot of work...
Probably we first have to implement an offline search engine
(something similar as provided by the R-stats where you can search
within local manual pages). Any ideas?
> An exception might be where only one of Delaunay/Voronoi is mentioned in
> the description, but I guess you could always rewrite the line it if
> need be.
> e.g. Debian's "apt-cache search foo" works on the included 2-3 sentence
> descriptions.
Nice!
Markus
