[GRASS5] [bug #2406] (grass) errors in v.digit from d.m and gui interface
Request Tracker grass-bugs at intevation.de
Thu May 13 00:31:29 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2406
Subject: errors in v.digit from d.m and gui interface
Platform: other
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.7  24-4-2004
V.digit no longer starts from d.m. Nothing happens when I click the "dig" button. When v.digit started from command line, the background commands still don't work--though they give a different error than they used to. Now they generate...
v.digit map=elevation_mask bgcmd=d.rast map=elevation_dem -n
Map does not exist.
New empty map created.
Illegal vector map name <elevation_mask,elevation_dem>. Character <,> not allowed.
ERROR: Map name not SQL compliant.
[Note Mac OSX is not an option on the OS pull-down]
I get the same error if I put the 'd.rast map=elevation_dem' clause in single quotes.
Michael Barton
-------------------------------------------- Managed by Request Tracker
