[GRASS5] [bug #2406] (grass) errors in v.digit from d.m and gui interface
Markus Neteler neteler at itc.it
Thu May 13 05:03:38 EDT 2004
On Thu, May 13, 2004 at 06:31:29AM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2406
> Subject: errors in v.digit from d.m and gui interface
> Platform: other
> grass obtained from: Other (CDROM etc)
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: 5.7  24-4-2004
> V.digit no longer starts from d.m. Nothing happens when I click the "dig" button.
Michael,
did you create a vector entry first in 'd.m'? And activated the layer?
Then the 'dig' item should work.
> When v.digit started from command line, the background commands still don't work--though they give a different error than they used to. Now they generate...
> v.digit map=elevation_mask bgcmd=d.rast map=elevation_dem -n
You are missing the quotes:
 v.digit map=elevation_mask bgcmd='d.rast map=elevation_dem' -n
Markus
