[GRASS5] Undefined `NAME_LEN' in Imagery lib on current CVS
Markus Neteler neteler at itc.it
Thu May 13 12:41:41 EDT 2004
Sorry for this, I forgot to upload the updated
src/include/imagery.h
Should be fixed now,
 Markus
PS: Was a bug for a few hours...
On Thu, May 13, 2004 at 03:27:07PM +0200, Luigi Pirelli wrote:
> This is the error in the current CVS grass 5.3 version.
>   SRC     = /home/riade/src/grass/grass-5.3_exp_13052004/src
>   CMD     = /home/riade/src/grass/grass-5.3_exp_13052004/src/CMD
>   UNUSED  = /home/riade/src/grass/grass-5.3_exp_13052004/unused
>   HEADER  = head.i686-pc-linux-gnu
>   ARCH    = i686-pc-linux-gnu
>   GISBASE =
>   /home/riade/src/grass/grass-5.3_exp_13052004/dist.i686-pc-linux-gnu
>   VERSION = 5.3-cvs 2004
> /home/riade/src/grass/grass-5.3_exp_13052004/src/libes/imagery
>   make -f OBJ.i686-pc-linux-gnu/make.rules
> gcc -I/home/riade/src/grass/grass-5.3_exp_13052004/src/include -g -O2
> -c ask_bands.c -o OBJ.i686-pc-linux-gnu/ask_bands.o
> ask_bands.c: In function `I_bandname':
> ask_bands.c:14: error: `NAME_LEN' undeclared (first use in this function)
> ask_bands.c:14: error: (Each undeclared identifier is reported only once
> ask_bands.c:14: error: for each function it appears in.)
> ask_bands.c:14: error: storage size of `name' isn't known
> make: *** [OBJ.i686-pc-linux-gnu/ask_bands.o] Error 1
> It is used only in Imagery Lib as shown:
> imagery/i.tape.tm.fast/cmd/tape.h:#define MAX_NAME_LENGTH 11
> imagery/i.tape.tm.fast/cmd/tape.h:    char name[MAX_NAME_LENGTH];
> imagery/i.tape.tm.fast/cmd/tape.h:    char grp_name[MAX_NAME_LENGTH];
> imagery/i.tape.tm3/fileseq.c:   fileseq->name = malloc(FILENAME_LEN);
> imagery/i.tape.tm3/fileseq.c:   fgets(fileseq->name, FILENAME_LEN, stdin);
> imagery/i.tape.tm3/fileseq.h:#define FILENAME_LEN       100
> include/vect/dig_head.h:#define DIG_YOUR_NAME_LEN   20
> include/vect/dig_head.h:#define DIG_MAP_NAME_LEN    41
> libes/dbmi/drivers/odbc/listtab.c:    SQLCHAR
> tableName[SQL_MAX_TABLE_NAME_LEN];
> libes/imagery/ask_bands.c:    static char name[NAME_LEN];
> libes/imagery/group.c:    char name[NAME_LEN], mapset[NAME_LEN];
> libes/imagery/nfiles.c:    char name[NAME_LEN], mapset[NAME_LEN];
> libes/imagery/vask_group.c:    char tgroup[NAME_LEN], tsubgroup[NAME_LEN];
> libes/imagery/vask_group.c:     V_ques (group, 's', line++, 10, NAME_LEN);
> libes/imagery/vask_group.c:     V_const (group, 's', line++, 10, NAME_LEN);
> libes/imagery/vask_group.c:     V_ques (subgroup, 's', line++, 10,
> NAME_LEN);
> libes/vect32/Vlib/init_head.c:#define DIG_YOUR_NAME_LEN   20
> libes/vect32/Vlib/init_head.c:#define DIG_MAP_NAME_LEN    41
> libes/vect32/Vlib/init_head.c:    strncpy (to->your_name, from->your_name,
> DIG_YOUR_NAME_LEN);
> libes/vect32/Vlib/init_head.c:    strncpy (to->map_name, from->map_name,
> DIG_MAP_NAME_LEN);
> libes/vect32/Vlib/x_rw_binary.c:
> dhead->your_name[DIG_YOUR_NAME_LEN-1] = 0;
> libes/vect32/Vlib/x_rw_binary.c:        dhead->map_name[DIG_MAP_NAME_LEN-1]
> = 0;
> libes/vect32_64/Vlib/init_head.c:#define DIG_YOUR_NAME_LEN   20
> libes/vect32_64/Vlib/init_head.c:#define DIG_MAP_NAME_LEN    41
> libes/vect32_64/Vlib/init_head.c:    strncpy (to->your_name,
> from->your_name, DIG_YOUR_NAME_LEN);
> libes/vect32_64/Vlib/init_head.c:    strncpy (to->map_name, from->map_name,
> DIG_MAP_NAME_LEN);
> libes/vect32_64/Vlib/x_rw_binary.c:
> libes/vect32_64/Vlib/x_rw_binary.c:     dhead->map_name[DIG_MAP_NAME_LEN-1]
> = 0;
> mapdev/v.transform/main.c:        /* truncate if string >
> DIG_MAP_NAME_LEN-1 */
> mapdev/v.transform/main.c:        buf[DIG_MAP_NAME_LEN-1] = '\0';
> raster/r.contour/main.c:    strncpy (Head.map_name, mapname,
> DIG_MAP_NAME_LEN); /* uses GISLIB strncpy() */
> raster/r.contour/main.c:    mapname[DIG_MAP_NAME_LEN - 1] = '\0'; /* ensure
> that mapname is properly terminated */
> Where is the problem? some missed in imagery.h?
> BeSoS Luis
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
