[GRASS5] Undefined `NAME_LEN' in Imagery lib on current CVS
Luigi Pirelli
l.pirelli at acsys.it
Thu May 13 09:27:07 EDT 2004
This is the error in the current CVS grass 5.3 version.
SRC = /home/riade/src/grass/grass-5.3_exp_13052004/src
CMD = /home/riade/src/grass/grass-5.3_exp_13052004/src/CMD
UNUSED = /home/riade/src/grass/grass-5.3_exp_13052004/unused
HEADER = head.i686-pc-linux-gnu
ARCH = i686-pc-linux-gnu
GISBASE = /home/riade/src/grass/grass-5.3_exp_13052004/dist.i686-pc-linux-gnu
VERSION = 5.3-cvs 2004
/home/riade/src/grass/grass-5.3_exp_13052004/src/libes/imagery
make -f OBJ.i686-pc-linux-gnu/make.rules
gcc -I/home/riade/src/grass/grass-5.3_exp_13052004/src/include -g -O2 -c
ask_bands.c -o OBJ.i686-pc-linux-gnu/ask_bands.o
ask_bands.c: In function `I_bandname':
ask_bands.c:14: error: `NAME_LEN' undeclared (first use in this function)
ask_bands.c:14: error: (Each undeclared identifier is reported only once
ask_bands.c:14: error: for each function it appears in.)
ask_bands.c:14: error: storage size of `name' isn't known
make: *** [OBJ.i686-pc-linux-gnu/ask_bands.o] Error 1
It is used only in Imagery Lib as shown:
imagery/i.tape.tm.fast/cmd/tape.h:#define MAX_NAME_LENGTH 11
imagery/i.tape.tm.fast/cmd/tape.h: char name[MAX_NAME_LENGTH];
imagery/i.tape.tm.fast/cmd/tape.h: char grp_name[MAX_NAME_LENGTH];
imagery/i.tape.tm3/fileseq.c: fileseq->name = malloc(FILENAME_LEN);
imagery/i.tape.tm3/fileseq.c: fgets(fileseq->name, FILENAME_LEN, stdin);
imagery/i.tape.tm3/fileseq.h:#define FILENAME_LEN 100
include/vect/dig_head.h:#define DIG_YOUR_NAME_LEN 20
include/vect/dig_head.h:#define DIG_MAP_NAME_LEN 41
libes/dbmi/drivers/odbc/listtab.c: SQLCHAR tableName[SQL_MAX_TABLE_NAME_LEN];
libes/imagery/ask_bands.c: static char name[NAME_LEN];
libes/imagery/group.c: char name[NAME_LEN], mapset[NAME_LEN];
libes/imagery/nfiles.c: char name[NAME_LEN], mapset[NAME_LEN];
libes/imagery/vask_group.c: char tgroup[NAME_LEN], tsubgroup[NAME_LEN];
libes/imagery/vask_group.c: V_ques (group, 's', line++, 10, NAME_LEN);
libes/imagery/vask_group.c: V_const (group, 's', line++, 10, NAME_LEN);
libes/imagery/vask_group.c: V_ques (subgroup, 's', line++, 10, NAME_LEN);
libes/vect32/Vlib/init_head.c:#define DIG_YOUR_NAME_LEN 20
libes/vect32/Vlib/init_head.c:#define DIG_MAP_NAME_LEN 41
libes/vect32/Vlib/init_head.c: strncpy (to->your_name, from->your_name,
DIG_YOUR_NAME_LEN);
libes/vect32/Vlib/init_head.c: strncpy (to->map_name, from->map_name,
DIG_MAP_NAME_LEN);
libes/vect32/Vlib/x_rw_binary.c: dhead->your_name[DIG_YOUR_NAME_LEN-1] = 0;
libes/vect32/Vlib/x_rw_binary.c: dhead->map_name[DIG_MAP_NAME_LEN-1] = 0;
libes/vect32_64/Vlib/init_head.c:#define DIG_YOUR_NAME_LEN 20
libes/vect32_64/Vlib/init_head.c:#define DIG_MAP_NAME_LEN 41
libes/vect32_64/Vlib/init_head.c: strncpy (to->your_name, from->your_name,
DIG_YOUR_NAME_LEN);
libes/vect32_64/Vlib/init_head.c: strncpy (to->map_name, from->map_name,
DIG_MAP_NAME_LEN);
libes/vect32_64/Vlib/x_rw_binary.c: dhead->your_name[DIG_YOUR_NAME_LEN-1] = 0;
libes/vect32_64/Vlib/x_rw_binary.c: dhead->map_name[DIG_MAP_NAME_LEN-1] = 0;
mapdev/v.transform/main.c: /* truncate if string > DIG_MAP_NAME_LEN-1 */
mapdev/v.transform/main.c: buf[DIG_MAP_NAME_LEN-1] = '\0';
raster/r.contour/main.c: strncpy (Head.map_name, mapname, DIG_MAP_NAME_LEN);
/* uses GISLIB strncpy() */
raster/r.contour/main.c: mapname[DIG_MAP_NAME_LEN - 1] = '\0'; /* ensure that
mapname is properly terminated */
Where is the problem? some missed in imagery.h?
BeSoS Luis
