[GRASS5] Re: rules in r.colors
Michael Barton michael.barton at asu.edu
Fri May 14 19:55:06 EDT 2004
Glynn,
I understand this and how it is supposed to work the way you have it
set up. Sorry if I was confusing in this regard. My suggestion was to
build on your work in a somewhat different direction. With the new
rules code you did, it is possible to read in text files of color
rules. I was suggesting to use this same code to access user-defined
files rather than a limited set of color table files located in the
$GISBASE/etc/colors folder. It is indeed a different objective than
yours was.
Perhaps it is problematic to do this. Having a set of predefined GRASS
color tables is certainly handy (realizing that grey.eq, grey.log, and
random are somewhat different beasts from the other color tables). For
different reasons, it also seems a useful thing to build into r.colors
the functionality of  'r.colors input=[map] <colortable.txt' so that a
user could more easily access (and even share) custom color tables. The
latter should not get mixed up with the standard predefined set.
I can't quite envision your suggestion for replacing the stdin option,
but it seems interesting. While it is very handy to be able to create a
color table on the fly as you can now, it would be even nicer to have
the option to save this to a file (as I think you are suggesting?) to
use again for various maps if you liked it (and not have to dig it out
of the $GISBASE/$LOCATION/$MAPSET/colr directory (the rast=[map] option
is a more efficient way of achieving the latter).
All in all, GRASS has some very nice and diverse ways of managing
colors for raster files. Maybe it is already pretty much as good as it
can get without a lot of trouble. But this discussion seems useful.
Thanks for the work you've put into this.
Michael Barton
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On May 14, 2004, at 4:02 PM, grass5-request at grass.itc.it wrote:
> No. As I've said at least twice before, that is *not* the purpose of
> the "rules=" option. The "rules=" option is intended solely as a
> transitional measure.
> The fact that the arguments to rules= happen to be files is an
> implementation detail, which shouldn't be visible to the user.
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040514/72afa36a/attachment.bin
