[GRASS5] Re: libcrypt and cygwin too
Michael Barton
michael.barton at asu.edu
Fri May 14 19:25:36 EDT 2004
The Cygwin binaries that Rich Greenwood kindly provided have a similar
issue. NVIZ won't run unless there is a specific version of cygcrypt
(that seems to accompany postgres) available.
Michael Barton
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On May 14, 2004, at 4:02 PM, grass5-request at grass.itc.it wrote:
> On Fri, May 14, 2004 at 11:18:12AM +0100, Glynn Clements wrote:
>> Markus Neteler wrote:
>>>> libcrypto.so.1 is needed by grass-5.3.0-1
>>> probably due to PostGRESQL support?
>> This dependency is almost certainly bogus. The PostgreSQL modules
>> require libpq. If libpq happens to require libcrypto, then it is up to
>> the RPM which contains libpq to deal with that. GRASS shouldn't list
>> it as a dependency.
>>>> libssl.so.1 is needed by grass-5.3.0-1
>>> I guess due to PostgreSQL support.
>> In which case, this is also bogus.
> Note that 'rpm -ba' has inserted these dependencies.
> Anyway, I have defined some more dependencies, now a new
> set of RPMs here:
> http://mpa.itc.it/markus/grass53/rpms/
> Still OGDI is required since I don't know how to manage
> two GDAL installations on one machine (my VMAP0/MapServer wants it).
> Markus
>> Glynn Clements <glynn.clements at virgin.net>
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040514/4647268f/attachment.bin
