[GRASS5] libz error compiling qgis
Jens Oberender
grass at troja.net
Mon May 17 07:16:40 EDT 2004
Hi Michael
> I am trying to compile QGIS on my Mac (OSX 10.3.3) to get some idea of
> where GRASS is heading. There is no assurance that it will compile on a
> Mac OSX 10.3.3--but there is no indication yet that it won't.
Latest CVS should work fine with Mac OSX, there were some changes to fix
endian problems.
> After a bit of futzing, my ./configure went well. But when I tried to
> do a make, it died with the following error.
> ld: /usr/local/pgsql/lib/libpq.a(fe-secure.o) illegal reference to
> symbol: _SSL_connect defined in indirectly referenced dynamic library
> /usr/lib/libssl.0.9.7.dylib
> symbol: _BIO_free defined in indirectly referenced dynamic library
> /usr/lib/libcrypto.0.9.7.dylib
> ld: warning multiple definitions of symbol _adler32
> /usr/lib/libz.1.1.3.dylib(adler32.o) definition of _adler32
> /usr/lib/libz.dylib(adler32.o) definition of _adler32
> ld: warning multiple definitions of symbol _crc32
> /usr/lib/libz.1.1.3.dylib(crc32.o) definition of _crc32
> /usr/lib/libz.dylib(crc32.o) definition of _crc32
> ld: warning multiple definitions of symbol _get_crc_table
> /usr/lib/libz.1.1.3.dylib(crc32.o) definition of _get_crc_table
> /usr/lib/libz.dylib(crc32.o) definition of _get_crc_table
> make[4]: *** [qgis] Error 1
> make[3]: *** [all-recursive] Error 1
> make[2]: *** [all] Error 2
> make[1]: *** [all-recursive] Error 1
> make: *** [all] Error 2
> I have been able to find references to others having problems with
> libz, but no one seems to indicate what program this library comes
> with. I thought before bugging the qGIS people, I'd see if any of you
> have some idea about this.
I'm not sure about that, but perhaps /usr/lib/libz.dylib must be a link to
/usr/lib/libz.1.1.3.dylib, when it's the same mechanism as on Linux.
If you have questions about qgis, you can come to the #qgis channel on
irc.freenode.net or join the ml.
Ciao
Jens Oberender
Die Liebe ist ein seltsam Ding.
